Julew
Member level 1
Hello,
We have a design with CC2520 texas instruments RF chip (2.4Ghz 802.15.4). I have to improve the output of this RF component. The out is a balun+Pi+Antenna.
In balun and Pi network inductor are fixed (based on microstrip).
Ok, so these are the steps i´m going to follow:
1) mesasure VSWR of antenna in our enclosure. This way i know Z0 of antena.
2) measure S11 of Chip+Balun+Pi configuring chip as receiver and using a attenuator.
3) Modify Pi to match Chip+Balun+Pi>>>>Antenna
Another thing that i can do is try to maximize the output power changing capacitors and then make all them make all the rest. I have measure the output power to the antenna and here are the results:
Frequency Power
2405 Mhz 2.88 dBm
2445 Mhz 2.54 dBm
2480 Mhz 1.96 dBm
Do you think that i can improve the performance making another thing?
I have also a question about measuring S11 of Chip+Balun+Pi. I can´t configure the attenuator of VNA so i bought an external one (20dB). Today i try to measure S11 but i can´t calibrate the equipment with the attenuator (if i do this, when i connect load/oc/sc it goes crazy!) and if i attach it after calibration S11 of the attenuator is taken into account and the measure is not valid. How can make this measurement?
Frequency Power
2405 Mhz 2.88 dBm
2445 Mhz 2.54 dBm
2480 Mhz 1.96 dBm
