I have made a circuit using ISIS 7.1 and now I would like to design the Circuit PCB with Eagle Cadsoft (I have the 4.01 version), I found in ISIS that it is possible to compile the netlist in different formats (Multiwire,spice,tango,SDF,...), so, which one should I chose ? and how can I import it into Eagle and start the designing ?
I think the MULTIWIRE format is the one used by EAGLE PCB - needs to be exported in physical netlist mode.
Note that you will have to manually assign EAGLE footprints to ISIS components either in EAGLE if supported or in a text editor prior to netlist load if not.
