I am trying to interface tc65 and micro controller(R8 Tiny series) through i2c but i am not able to.With same code i am able to interface two controller.
TC 65 provides some AT command for enabling I2C communication at TC65 End and i am using the same.Is any extra hardware circuitry require for TC 65.
I tried the same.
Through uart i am enabling the i2c on tc65 but if i am trying to see at SCLK pin of tc65 ,then i am not getting clock itself.I thought might be it is tc65 problem , i changed that also but problem remains same.
I pulled up the resistor.
Controller supports I2C communication hardware .I am using r8c1B micro controller and for that i have written slave receiver and slave transmitter code.
the code is perfectly working when i am using two micro controller .One as a slave and other as a master but with tc65 i am not able to find out why it is not working. If i am checking clock at SCLK of tc65 , i am not getting clock itself
The TC65 works as the master of I2C bus so the uC should act as slave. You have to command the TC65 throw the UART to open the I2C hardware using the AT^SSPI command. You also have to put pull-up resistor from TC65_SCL to TC65_VDD and from TC65_SDA to TC65_VDD. I put 10k resistor.
