implementeting PID in mikroC for pic
Vlad.
Full Member level 3
Bucharest/Romania
Hey guys, i try to make a code in mikroC but i can make the PID controoler to work. ok here is the code to genetare pwm and control the duty cycle.
Code: Select all
unsigned short DutyCycle=0;
unsigned int adc_value;
void main() {
PWM1_Init(10000);
PWM1_Start();
PWM1_Set_Duty(DutyCycle);
do {
adc_value = ADC_Read(0);
DutyCycle = adc_value >> 2; // Convert 10-bit ADC value to 8-bit
} while(1);
I want to read a voltage from a curent sense rezistor series with the source of the mosfet.
Who can help me with a code? Thanks.
If you have a very low value resistor in line you can read the voltage across the resistor.
