subramaniam1990
Newbie level 3
- Joined
- Mar 19, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,310
hi,
I am currently working on a project on implementation of floating point arithmetic...in that i have to implement barrel shifter. .. iam using verilog coding for it..i have coded it...can you just tell me if its right..it will be great if you could help me out..i would like to know if I am moving in right direction.. thank you
this code is for shifting it towards right:
module barrel_shifter(ip , op , shift , clk, load_in , load_out , load_shift);
input ip[31:0];
input shift[4:0];
input clk;
input load_in;
input load_out;
input load_shift;
output op[31:0];
always @(load_in,clk)
begin
if(clk==1)
begin
if(load_in == 1)
begin
buffer_in <= ip;
end
else
begin
buffer_in <= 0;
end
end
end
always @(load_shift,clk)
begin
if(clk==1)
begin
if(load_shift == 1)
begin
buffer_shift <= shift;
end
else
begin
buffer_shift <= 00000;
end
end
end
always @(load_in , load_shift , buffer_in, buffer_shift)
begin
if(buffer_shift[4] == 1)
begin
out_shift4 <= {buffer_in[15:0],buffer_in[31:16]};
end
else
begin
out_shift4 <= buffer_in;
end
end
always @(load_in , load_shift , buffer_shift, out_shift4)
begin
if(buffer_shift[3] ==1'b1)
begin
out_shift3 <= {out_shift4[7:0],out_shift4[31:8]};
end
else
begin
out_shift3 <= out_shift4;
end
end
always @(load_in , load_shift , buffer_shift, out_shift3)
begin
if(buffer_shift[2] ==1)
begin
out_shift2 <= {out_shift3[3:0],out_shift3[31:4]};
end
else
begin
out_shift2 <= out_shift3; //check condition
end
end
always @(load_in , load_shift , buffer_shift, out_shift2)
begin
if(buffer_shift[1] ==1)
begin
out_shift1 = {out_shift2[1:0],out_shift2[31:2]};
end
else
begin
out_shift1 <= out_shift2; //check condition
end
end
always @(load_in , load_shift , buffer_shift, out_shift1)
begin
if(buffer_shift[0] ==1)
begin
out_shift0 <= {out_shift1[0],out_shift1[31:1]};
end
else
begin
out_shift0 <= out_shift1; //check condition
end
end
always @(clk, load_out)
begin
if(clk==1)
begin
if(load_out==1)
begin
op = out_shift1;
end
else
begin
op = 0;
end
end
end
endmodule
is this code fine or should i use case statements directly using diff combinations as case statements..
regards
subramaniam
input ip[31:0];
input shift[4:0];
input clk;
input load_in;
input load_out;
input load_shift;
output op[31:0];
begin
if(clk==1)
begin
if(load_in == 1)
begin
buffer_in <= ip;
end
else
begin
buffer_in <= 0;
end
end
end
begin
if(clk==1)
begin
if(load_shift == 1)
begin
end
else
begin
end
end
end
begin
begin
end
else
begin
end
end
begin
begin
end
else
begin
end
end
begin
begin
end
else
begin
end
end
begin
begin
end
else
begin
end
end
begin
begin
end
else
begin
end
end
begin
if(clk==1)
begin
if(load_out==1)
begin
op = out_shift1;
end
else
begin
op = 0;
end
end
end
endmodule
regards
subramaniam
