Hi,I would like to know if there is a way to implement a state machine in microblaze processor to control two other peripherals. Is there any tutorial that will help me out with this issue.
I think you can not write state machine synchronous to clk in a processor. Seems something odd.
Actually simple if-else program will work for you. it is as good as state machine. because, instruction execution took place according to core clock.
Well, for one thing, a hardware state macine will react instantly to the controlling stimuli, while a software state machine might exhibit a little latency, as it goes through it's program loop. That generally isn't a problem, and can be ingnore for most applications.
