impedence matching of two equipments
shahbaz.ele
Advanced Member level 1
Islamabad, Pakistan
dear all
I have a device for measuring time in pico seconds which has an input impedence of 50ohm.
but my circuit (op amps) has high impedence, how can i match both impedencs.
is there any idea to make my circuit output 50ohm.
A typical op amp can only drive about 5 mA so the maximum output into 50 ohms will be only 250mV peak.
or you can use a voltage follower opamp circuit to nullify the o/p impedence of your opamp circuit
