xavierr
Newbie level 2
Hello,
I have a problem during testing some IC. It has mosfet totem pole output (push-pull?). In ON state has 100Ohm resistance, in OFF state 100kOhm. Output capacitance is let say (not remember exactly now) 100pF.
I have the setup as in the picture - 500MHz oscilloscope and 10x probe. I'd like to connect the probe with IC pin by means of coaxial cable. What kind of matching should be used in the red rectangle region? Paralell 50Ohm resistor? How to make a simulation for that? Output signal is 5V square wave 50kHz. How to match in order to obtain the best fidelity of signal? Is the model I've done in LTSpice ok? I like to use 50Ohm cable (50Ohm is Z0, but what exactly impedance sees 50kHz square signal form IC side? - should I model Coax with L&C lumped parameters to get best simulation?)
