Sep 29, 2006 #1 S sasilatha Newbie level 4 Joined Sep 15, 2006 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,307 hai , I need to implement the following formule using matlab m(x,y) = 1/ Nη Σ (s,t) ε η(x,y) I(s,t) where η(x,y) is a set of neighbouring pixels centering at (x,y), m(x,y) is the sample mean of I (x,y) and Nη is the size of η. where I(s,t) may be any pixel in the given image. I need help to implement the above formula
Sep 29, 2006 #2 S Sal Full Member level 4 Joined Nov 29, 2005 Messages 234 Helped 53 Reputation 106 Reaction score 13 Trophy points 1,298 Activity points 3,034 Hi your expression is a bit unclear, what is \sum (s,t) \epsilon ? if you are more specific I may help cheers Sal
Sep 30, 2006 #3 I itsthetimetodisco Member level 4 Joined Jul 21, 2006 Messages 76 Helped 7 Reputation 14 Reaction score 6 Trophy points 1,288 Activity points 1,664 please explain the meaning of variables in your equation..that will let other throw some insight in the problem.
