So I've been working on this project for class...
Using Verilog, design an adder-subractor-multiplier circuit that will perform these operations on 2
3-bit numbers as follows,
Use SWO-SW2 to represent the first 3-bit number (least significant). This digit will be
displayed on 7-segment display HEX2
Use SW3-SW5 to represent the second 3-bit number (most significant). This digit will be
displayed on 7-segment display HEX3
Pressing pushbutton KEY0 will perform addition on the 2 digits selected by the switches
Pressing pushbutton KEY1 will perform subtraction on the 2 digits selected by the switches
Pressing pushbutton KEY2 will perform multiplication on the 2 digits selected by the
switches
The result of any operation will be displayed on segment displays HEX1-HEX0.
Subtraction will only be allowed if the second digit is greater than the first one. Otherwise,
the display should be blank.
o For example if SW3SW4SW5 = 310 and SW0SW1SW2 = 910 then
KEY0 pressed will show 12
KEY1 pressed will show Blank display
KEY2 pressed will show 27
o For example if SW3SW4SW5 = 810 and SW0SW1SW2 = 510 then
KEY0 pressed will show 13
KEY1 pressed will show 3
KEY2 pressed will show 40
If not KEY is pressed, HEX1-HEX0 should be blank.
and this is what I have thus far...
Code ActionScript - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
| module top(most, least, key0, key1, key2, lights);
input [2:0] most;
input [2:0] least;
input key0, key1, key2;
output [1:14] lights;
wire [5:0] result;
wire [3:0] ones;
wire [3:0] tens;
if(key0==1)
begin
adder add0(most, least, result);
end
else if(key1==1)
begin
subtractor sub0(most, least, result);
end
else if(key2==1)
begin
mulitplier mult0(most, least, result);
end
else
begin
seg7 dip0(most,lights[1:7]);
seg7 dip1(least,lights[8:14]);
end
if(result>9)
begin
binary_to_BCD(result,ones,tens);
seg7 dip2(tens, lights[1:7]);
seg7 dip3(ones, lights[8:14]);
end
else
begin
seg7 dip4(result, lights[8:14]);
end
endmodule
//Subtracts numbers when msb>lsb
module subtractor(Z, W, SUB);
input [2:0] Z;
input [2:0] W;
output reg [3:0] SUB;
always@(Z,W)
if (Z >= W)
begin
assign SUB = Z - W;
end
endmodule
//Adds numbers
module adder(Q, R, S);
input [2:0] Q;
input [2:0] R;
output reg [3:0] S;
always@(Q,R)
assign S = Q + R;
endmodule
//Multilies numbers
module mulitplier(T, U, M);
input [2:0] T;
input [2:0] U;
output [5:0] M;
assign M = T * U;
endmodule
//7_segment decoder
module seg7(bcd,leds);
input [3:0]bcd;
output reg [1:7] leds;
always@(bcd)
case(bcd) //abcdefg
0: leds = 7'b1111110;
1: leds = 7'b0110000;
2: leds = 7'b1101101;
3: leds = 7'b1111001;
4: leds = 7'b0110011;
5: leds = 7'b1011011;
6: leds = 7'b1011111;
7: leds = 7'b1110000;
8: leds = 7'b1111111;
9: leds = 7'b1111011;
default: leds = 7'b0000000;
endcase
endmodule
//converts from binary to bcd for numbers >9
module binary_to_BCD(A,ones,tens);//c1,c2,c3,c4,d1,d2,d3,d4);
input [5:0] A;
output [3:0] ones, tens;
wire [3:0] c1,c2,c3,c4;
wire [3:0] d1,d2,d3,d4;
assign d1 = {1'b0,A[5:3]};
assign d2 = {c1[2:0],A[2]};
assign d3 = {c2[2:0],A[1]};
add3 m1(d1,c1);
add3 m2(d2,c2);
add3 m3(d3,c3);
assign one = {c3[2:0],A[0]};
assign tens = {1'b0,c1[3],c2[3],c3[3]};
endmodule
//assigns binary a bcd
module add3(in,out);
input [3:0] in;
output [3:0] out;
reg [3:0] out;
always @ (in)
case (in)
4'b0000: out <= 4'b0000;
4'b0001: out <= 4'b0001;
4'b0010: out <= 4'b0010;
4'b0011: out <= 4'b0011;
4'b0100: out <= 4'b0100;
4'b0101: out <= 4'b1000;
4'b0110: out <= 4'b1001;
4'b0111: out <= 4'b1010;
4'b1000: out <= 4'b1011;
4'b1001: out <= 4'b1100;
default: out <= 4'b0000;
endcase
endmodule |
It won't compile giving me errors about redeclaration and expecting endmodule near my ends. All these errors appear in my top module.
I know I'm probably just doing/not doing something incredibly stupid simple, but any help would be more than appreciated. :-D
