IGBT series connection - how to turn them on synchronously?
electtron
Junior Member level 2
igbt series
When IGBTs are connected in series (for high voltage switching, the voltage rating of a single IGBT would not be sufficient and hence they would be connected in series, so that the voltage gets divided across these IGBTs), how can they be turned ON synchronously. How is the design taking care of this series connection of IGBTs
Re: IGBT series connection
They needn't be absolutely synchronous. Even if they are near synchronous its fine. If both the IGBTs don't turn on the circuit will just continue to work as if both IGBTs were off.
Generally both IGBTs are driven by the same driver pulse. So they will turn on near simultaneously.
