Hello!
I am building a Full-Bridge DC-DC Converter with the following specifications.
Vin: 48V DC
Vout: 400 V DC
Pout: 1500 W
After considering the transformer efficiency of 80%,
Pin = 1500/0.8 = 1875 W
This makes Iin = 1875 W/ 48 V
=39 Amps
I am a bit confused while selecting the package of the input power devices, because I haven't dealt with this degree of current in my earlier projects.
My first thought was to construct the full bridge using 2 half bridge IGBT modules of 600V / 75A (Powerex CM75DU-12F) and the DC input contacts between the 2 modules would be made via 1mm thick copper bars.
Secondly, I thought of using 2 x IKW75N60T paralleled replacing each switch position on the full-bridge, i.e. 8 IGBTs used in all. All these IGBTs would be mounted on a PCB and the DC supply would be given via thick traces + metal interconnects on the PCB.
The converter is expected to run for minimum 5 hours daily. What would be a more feasible solution for such a long term usage? I personally would want to go for the first configuration.
Also is there any better mounting procedure that would be useful in this application? Thanks!
