Do ganged IGBTs have a greater pulsed current handling ability? Another words 2 ganged parts capable of 5 amps each would be able to handle 10 amps nominally, is this the case?
Short answer = yes, long answer is that the wiring needs to be symmetric as does the gate drive, heat-sinking needs to be the same, ideally close to each other, and the Von should go up with temp for long term sharing ...
