IGbt driver ( IR2110 )
m.heshmat
Newbie level 5
Newbie level 5
can anyone help me to design IR2110 for full bridge inverter instead of using transistor
download IR2110 datasheet and your problem will be solved.
yes , i want igbt driver circuit using IR2110
IR2110 does not have isolation
You need two IR2110 since it is half bridge driver. But you should also use opto-coupler between microcontroller and gate driver. I assume you have considered shoot through.
I was wondering what steps I would need to learn in order to interface an optocoupler with a PIC output?
which one can i use (opto-couplers ) between microcontroller and driver ?
4n25-4n27-4n35-4n136-4n137-CNY17-3 -moc3022 - moc3063 - pc817- TLP521 - TLP621 _TLP631
how many opto-coupler for each igbt ir2110 driver should i use ?
