Re: IFC Engine- & enviroment analog sensordata to NME2000 bus through Teensy3.6 (mari
Hello Klaus,
thank you for your reply. Some thing I'd like to mention.
You say you want isolation.
We only know that there is a power supply and a sensor input.
If you want isolation between them, then I agree with Eric, that isolating the power supply is the better solution..because isolating the analog signal may introduce a lot of errors.
This device shell be used in the marine enviroment as I wrote in the post and mentioned in the thread header. The NMEA2000 bus or more the protocol was created by the National Marine Electronic Association. It is the same kind of CAN bus type (modified) like you find in all modern cars.
Since I don't want to do this just for my self and would like to give it also to friends and others which like to get their old engines and marine sensors shown on their new MultiFunctionDisplay.
Now your concern is to scale down the analog signal.
If your input signal is 0...14.4V, then I recommend to scale down from 15V or even more.
The resolution of 12V with 13 bits is 1.465mV
14.4V--> 1.758mV
15.0V --> 1.831mV
Do you really care about the 366uV (loss of resolution)? ...at a stepsize of 1.5mV?
I assume all other errors are higher than those 366uV.
For sure the "pure DAC value" will differ a lot, but you need to compensate this with the divider ratio in any case.
The 13 bit is the resolution of the analog inputs of the Teensy's which I was writing about. I think any Teensy or arduino will just burn away using 12v at the analog inputs as you can use here just % v max in some cases. I did worte this:
The Teensy 3.6 have 3.3 v analog inputs with 13 bit usable resulution.
Like in most 12 V based car / boat systems you have the 12 V from your battery and the approx. 14,4 V from the generator. Which resutls in that we don have 15 V available. To keep the 12/14,4V is neccessary to be able to use the analog gauges as well.
...but before you worried about 366uV --> using VCC as voltage referenc may drop accuracy performance by a factor of 3200!
I am not sure where you got that from?
Voltage regulator, 7812:
I don't know how you want to use it, since it needs an input voltage of at least 15V to operate correctly (I don't know the exact value. Read the datasheet)...as you correctly mentioned.
I don't see where you have "at least 15V"
Also I don't see where 12V are used. Maybe for the sensors?
Yes I thought to use easily a 7812 to get the difference between 12 V and 14.4 V away. 12 Volt because due to older gauges which still shell be functional. 14.4 are 120% of 12 V. This is a huge difference, isn't it? I wrote
...but the most Voltage regulators I could find needs always 15V minimum as input voltage.
Look for "LDO" for less voltage drop regulators. But they still need higher input voltage than output voltage.
The next better, but more expensive, solution are SEPIC or Push_pull switching regulators. They are able to generate regulated output voltage with input voltages higher or lower than the output voltage.
Thank you for this, thas is an usefull information for me!
If you use a 78xx regulator, then you need one with a lower output voltage, like 7809, to get a stable, regulated output.
Same as above. I need to use the 12 V or the sensors which are already in place to be able to use the old analog gauges as well.
Potentiometer:
I don't remember that I ever used a potentiometer with an ADC / microcontroller system.
It's far more precise, stable, better for automated calibration, part saving, cheaper.....to use software and microcontroller_inside_EEPROM for signal conditioning.
Klaus
If you want to use this in a couple of boat's where already all sensors are in place and you don't want to change the sensors or solder around on the board, how can you than adjust the voltage devider if not by potentiometers?
Klaus, for me it looks like my post wasn't intelligent enough for you and you didn't had the time to read carefully enough what I wrote. That you pointed me to the LDO's is may something I can use. But the rest you answered I think do not have a lot todo with my questions. I did posted the same text in three other forum and I got a complete different kind of answers.
It is a long time ago that I last worked with electronics ( about 20 years ago) but what is the meening of this forum if it is not alowed to post questions which are not based on a complete finished design.
Thank you and have nice week!
