#if undefined identifier in keil
embpic
Advanced Member level 3
india
hello frnds
i was doing and trying to compile code with micro #if but it gives me error of undefined identifier at #if.
my code is
sbit sw1=P0^0;
#if sw1==0
sbit led1=P1^0;
#else
sbit led1=P1^2;
#endif
thanx
even i try by #defined that var.
and also
#if sw1 alzo
u may try this
#define sw1 p0^0;
#define led1 p1^0;
if(sw1==1)
led=0; // Assume on =0 off=1
else
led=1;
Yes thanx but i want to check sw condition in preprocessor so pin assigment can be changed. As i have shown.
Think! How should this work? The state of pin sw can't be known at compile time, thus it's impossible to take preprocessor actions based on it. Conditional preprocessor commands can only work with constant expressions.
I want to make code as change as per sw1 position.
Means do different if sw1is closed and do different if open.
You really need to think.
The compiler runs on your PC. How can it read the switch and perform conditional compilation based on it's state?
K thanx but is there any way to assign pin no to different depend upon switch condition.
And which condion fan be checked with
#if
Once again thanx.
Never Make programming complex by changing basic. If Ur SW sensing is possible during running condition & u can make action according
which condion can be checked with #if
as said constant expressions, e.g. compiler version, defined hardware targets, software revision
All regular processor instructions. In detail, you have to check which instructions can be used effectively for a particular processor.
If I/O-bits are acessed with bit set instructions, as for 8051 or PIC, it's probaly best to write alternative code blocks or even complete functions that are selected depending on the hardware switch.
Reactions: embpic
    embpic
Got it . Means to make code portable to run on different hardware or compiler.
Do you have any examples to use me portability in my codes.
You compile your code in your PC and run that hex file in your board, or large quantity product, how it is possible that your PC find out that what is status of that PIN in your large quantity Product and compile accordingly.
Regards,
Yes i was in thinking in different way till posting this query. After having reply from frnds i got the true...
Thanx
