IF-ELSE statement in hspice
srini.pes
Member level 3
Member level 3
NIT calicut
Hi to all.,
While designing my hspice model, i have a conditional statement
like
.if (V<s1)
.PARAM CURRENT='A'
.else(V>=s1)
.PARAM CURRENT='B'
.endif
it was showing some error like
please contact encrypted file provider. For relaxed syntax check, please use '-R' command and retry.
Please clarify me if some thing wrong in my syntax.
Thanking you....
SRINI
I think the .else keyword doesn't have to be followed by a condition (V>=s1). It's redundant anyway.
Again same error was coming.
Actually what is the meaning of this error exactly.
and the way i mentioned the if-else block was correct or not ??
Please clarify this and thanking you so much
SRINI
Are you sure the dot should be there? e.g.
if (Ps > Weff)
   Cbs = AS * Cjbs + (PS - Weff) * Cjbssw + Weff *Cjbsswg
else
   Cbs = AS * Cjbs + PS * Cjbsswg
Keith
Hi keith,
It must be like .if,
i clarified with hspice command reference document also...
.IF (condition1)...
+ [.ELSEIF (condition2)... ]
+ [.ELSE ... ]
.ENDIF
I think it depends on where you are using it. In a netlist you use .if, as a compiler directive you use #if and within a model you use if with no prefix.
Keith
I think this error message didn't result from HSPICE itself, but from a (SKILL decryption?) syntax checker.
Perhaps this error message doesn't really matter for the proper HSPICE analysis.
However i mention the if-else block having this same error.
Please tell me how to resolve this issue.
Then probably your if-else block isn't the reason for the error message.
How did you try and start the hspice analysis? Show the command line, and - if possible - the full hspice command file you want to run.
