Nov 23, 2009 #1 D drbizzarow Advanced Member level 1 Joined May 24, 2006 Messages 414 Helped 25 Reputation 50 Reaction score 15 Trophy points 1,298 Activity points 3,662 3 volt PIC possible ?? ASA 2 ALL folks i need pic microcontrollers with 3 operating voltage please help me how is it possible ???
Nov 23, 2009 #2 M madhan7710 Junior Member level 2 Joined Jun 19, 2007 Messages 20 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,394 Re: 3 volt PIC possible ?? All most every PIC have Low voltage versions... it will work from 2V.. Ex : PIC16LF628A Regards, Madhan
Nov 23, 2009 #3 M miredox Member level 4 Joined Oct 21, 2009 Messages 76 Helped 9 Reputation 18 Reaction score 4 Trophy points 1,288 Activity points 1,791 Re: 3 volt PIC possible ?? Most PICs operate with any (regulated) voltage between 2 and 5.5V.
Nov 24, 2009 #4 D drbizzarow Advanced Member level 1 Joined May 24, 2006 Messages 414 Helped 25 Reputation 50 Reaction score 15 Trophy points 1,298 Activity points 3,662 3 volt PIC possible ?? is also with 18f452 ???
Nov 24, 2009 #5 M miredox Member level 4 Joined Oct 21, 2009 Messages 76 Helped 9 Reputation 18 Reaction score 4 Trophy points 1,288 Activity points 1,791 Re: 3 volt PIC possible ?? If you have a look at the datasheet of the PIC18F452 (which is now replaced with PIC18F4520) -> **broken link removed** page 1: Wide operating voltage range (2.0V to 5.5V)
Nov 24, 2009 #6 D drbizzarow Advanced Member level 1 Joined May 24, 2006 Messages 414 Helped 25 Reputation 50 Reaction score 15 Trophy points 1,298 Activity points 3,662 do i need regulator if i am using battery for operating voltage and battery voltage lies between (2.0V to 5.5V) range ??
Nov 24, 2009 #7 nandhu015 Advanced Member level 5 Joined Feb 11, 2006 Messages 1,960 Helped 300 Reputation 600 Reaction score 222 Trophy points 1,353 Location India Activity points 9,924 drbizzarow said: do i need regulator if i am using battery for operating voltage and battery voltage lies between (2.0V to 5.5V) range ?? Click to expand... Not needed unless you are not using any charging circuit to charge the battery Nandhu
