ieee format journal
Hi
You may want to read the the IEEEtran_HOWTO more carefully, it is explained there. the CLASS document is the one classified as Visual Basic Class Module, (in fact it is windows problem not to show the file extension). The document tells you what to do with that file,
I don't have that PCTex32, but normally if you put the class file in the same directory as the document you are building, it should compile with no problem.
If this helps you press the "helped me" button for statistics
Sal
