Ideal CMFB specification
artho
Junior Member level 1
I want to design a fully differential op amp with a ideal CMFB. What is the gain and other specs that the CMFB amplifier have to be? And, as i'm using resistor divider to obtain the common-mode voltage, what is de ideal value of these resistors? I know that they have to be higher than the output impedance of the amplifier, but how high?
Thanks.
High enough as not to load the diff amp outputs unnecessarily. I'd say at least a factor of 5 .. 10 higher than its output impedance.
