exp
Full Member level 1
I am a bit confused about the input/output impedance of the ideal_balun of analogLib.
What resistance at the differential outputs is required so that the common mode input sees 50 Ohm?
I use a port with Vin=50mV and 50 Ohm. When I connect 50 Ohm to the port and look at the amplitude it is exactly what expected: 50mV.
However, when I connect the ideal balun to the port and then put the 50 Ohm to "n" and "p", the voltage is higher, 66mV.
I tried different factors of 1/2, 2, sqrt(2), 1/sqrt(2) etc.
Thank you.
Thank you.
