ICD2 Stolz and dsPIC30F3010
CapBlack
Junior Member level 1
icd2 dspic wiring
Hi all , I have this ICD2 made at home and work perfect with PIC16F876 & MPLAB
8.1 , just now connect one dsPIC 30F3010 and only get ID 0xFFF :?: some not good there :D
any comments/improvements welcome
regards
CapBlack
30f3010 program
blueroomelectronics said:
Did you connect the analog power & ground?
yes i did that , and pic 18F4450 also worked fine prg & deb.
I think dsPIC 30F shouldn't be aproblem with this programer.
Tanks.
CapBlack
dspic33 icd2
I have this ICD 2 clone :
http://www.chez.com/silicium31/Electronique/PIC/FreeIcdEnglish.htm
and it works perfect with PIC16/PIC18, I mean programming and debugging but there's no way to make it work with DSPIC...
"I think dsPIC 30F shouldn't be a problem with this programmer"...
I totally disagree with you...
Maybe PICKIT2 is the way to go.... $ 40 or at least a clone :D
icd2 dspic pgc2
HI again thanks to all 4 help , I dont know Hugo the line dsP30F are electrical = to 18F
if u mean 24F and 33F I agree with you .
CapBlack
pic30f avdd
The PICkit2 cannot currently debug the dsPIC30F. It can program it though.
The ICD2 and clones support the dsPIC30F3010 just fine. Make sure you have it connected properly. I've programmed a dsPIC30F3012 with my ICD2 clone just fine. It does have a very different pinout than a 16 or 18 series PIC. And you must connect VDD & AVDD to 5V and VSS & AVSS to gnd. can't leave them floating
dspic30f3010 clock
Hi all!
The clone ICD2 works perfectly with not only dsPIC30F but also dsPIC33F and PIC24F. The only thing is to make the right connections as already suggested by blueroomelectronics. Carefully cross check all your power, ground and Reset pins.
Regards.
Added after 16 minutes:
Hi!
Another important thing to remember while programming the dsPIC series is that it can be programmed serially thorugh different pairs of pins. The pins thorugh which you are going to program the chip must be specified in the configuration word. i.e
PGC/EMUC and PGD/EMUD
OR
EMUC1 and EMUD1
OR
EMUC2 and EMUD2
OR
EMUC3 and EMUD3
Select the ones to which you have connected your DATA and CLOCK line of ICD2.
Reagrds.
dspic avdd avss
Hi all , only remember one thing I have exactly Stolz clone without buffers on PG & PC because of that i wanted to use dsPIC30F .
i have been checking all coneccions which includes AVdd & AVss and they are fine. tomorow i wil try again with a new unit because maybe the first one was demaged because of me .
CapBlack
pickit2 dsp30f
HI all , I get the new unit and 30F3014 and surprise Stooz ICD2
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to target
Target Device dsPIC30F3014 found, revision = Rev 0x1001
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
Tanks all
CapBlack
pickit2 debug dspic30f config word
Hi , nothig ... the unit 30F3010 maybe was damage I check it later
