folks
Full Member level 3
- Joined
- Oct 30, 2006
- Messages
- 179
- Helped
- 32
- Reputation
- 64
- Reaction score
- 14
- Trophy points
- 1,298
- Location
- Guadalajara
- Activity points
- 2,337
folks said:ICD-U40 is a perfect solution for debugging and programming PIC. It's fully independant from MPLAB, well integrated in PCW and is quite cheap. It has very advantages vs ICD2, at least it's faster. Here is the circuit and PCB for those who want to make it themself.
nooknikz said:folks
very nice projects. How about debug on PCWH IDE ?
wjr1955 said:Hi Folks,
Nice job !
Can I use a max232 instead FT232 ?
If possible , DTR signal must be inverted ?
Thanks
bobyper said:You need to swap anode and cathode of LED LD4
18f452 is a 40 pin device, not a 20 pin device as 18f252. But if you arrange the PCB and the firmware should work without any problems with the correct fuse settings. Like disabling the extra peripherals of 18f452 with the fuses.dsMasoud said:is it possible to use 18f452 instead of 18f252 ?
if possible which firmware should be use?
nooknikz said:Hi folks
are you have eeprom for FT232RL ? And how to program to FT232RL ?
Thank you very much
