ICD 2, how to use it as DEBUGGER
mrcube_ns
Advanced Member level 1
Europe
I bought ICD2 LE.
It works nice as programmer :).
Is there any manual or instructions how to use it as debugger, to see values of variables in code, with breakpoints and similar.
Thanks in advance.
Mr.Cube
From MPLAB choose the Debug/ICD2 tool. You can VIEW watch variables and double click to set a breakpoint.
Also, if you're working with C some compiler should be set to use ICD debugging feature, usually this is a check that you've to set into the compiler option. Attached a screen shot example for the Hi-Tech PICC compiler, you've to set the flag in order to debug correctly the code, for production simply remove the flag and rebuild the project.
Bye
Pow
    mrcube_ns
