ICC help --- dc not loaded??
sicheng163
Member level 2
Chengdu,China
hi,
I'm not familiar with ICC, I used Astro before..
now I don't know why everytime I use derive_pg_connection to conncet P/G, ICC will prompt this:
derive_pg_connection -power_net VDD -power_pin VDD -ground_net VSS -ground_pin VSS
begin derive_pg_connection...
dc not loaded
--- connected 0 power ports and 0 ground ports
anyone knows why?thanks!!!
what is ICC.
Details required for futher help.
hi,
Hi
I don't know what does your error mean.
But I use derive_pg_connection to make logical connection between Power pings and power nets.
In my flow, first I create power pins and power nets through the UPF flow
then I make connections using
derive_pg_connection -create_nets
and then, after you did power network synthesis and you obtained your power straps
you connect them to cell's power/ground pins by
preroute_standard_cells
hope this help
good luck.
