ic610 in ubuntu8.04 error
holddreams
Full Member level 6
Shanghai
ic610 echo commands
When I open icfb&, the warning/error show in the CIW is as the following:
Loading ./.cdsinit init file from the site init file.
END OF SITE CUSTOMIZATION
*WARNING* (lookupTag): Can't open file /media/linux/ic610/tools/dfII/etc/context/schView.toc, because Too many open files
*WARNING* (lookupTag): Can't open file /media/linux/ic610/tools/dfII/etc/context/schematic.toc, because Too many open files
*WARNING* (lookupTag): Can't open file /media/linux/ic610/tools/dfII/etc/context/schHDL.toc, because Too many open files
*WARNING* (lookupTag): Can't open file /media/linux/ic610/tools/dfII/etc/context/analog.toc, because Too many open files
*WARNING* (lookupTag): Can't open file /media/linux/ic610/tools/dfII/etc/context/stv.toc, because Too many open files
*WARNING* (lookupTag): Can't open file /media/linux/ic610/tools/dfII/etc/context/verilogI.toc, because Too many open files
*Error* load: can't access file - "leBindKeys.il"
*Error* load: can't access file - "./.cdsinit"
So, how should I solve the errors?
Thanks.
Hi, I might help if you can post your .bashrc file here. I am not sure but it seems like some paths are missing in your .bashrc file.
    holddreams
My .bashrc is as the following:
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# If not running interactively, don't do anything
[ -z "$PS1" ] && return
# don't put duplicate lines in the history. See bash(1) for more options
export HISTCONTROL=ignoredups
# ... and ignore same sucessive entries.
export HISTCONTROL=ignoreboth
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then
debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
xterm-color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_colored_prompt=yes
if [ -n "$force_color_prompt" ]; then
if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
# We have color support; assume it's compliant with Ecma-48
# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
# a case would tend to support setf rather than setaf.)
color_prompt=yes
else
color_prompt=
fi
fi
if [ "$color_prompt" = yes ]; then
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
unset color_prompt force_color_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME}: ${PWD/$HOME/~}\007"'
esac
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
#if [ -f ~/.bash_aliases ]; then
# . ~/.bash_aliases
#fi
# enable color support of ls and also add handy aliases
if [ "$TERM" != "dumb" ] && [ -x /usr/bin/dircolors ]; then
eval "`dircolors -b`"
alias ls='ls --color=auto'
#alias dir='ls --color=auto --format=vertical'
#alias vdir='ls --color=auto --format=long'
#alias grep='grep --color=auto'
#alias fgrep='fgrep --color=auto'
#alias egrep='egrep --color=auto'
fi
# some more ls aliases
#alias ll='ls -l'
#alias la='ls -A'
#alias l='ls -CF'
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
alias lmli='/media/linux/ic610/tools/bin/lmgrd -c /media/linux/ic610/share/license/license.dat'
export OA_HOME=/media/linux/ic610/OA
export CDS_ROOT=/media/linux/ic610
export MMSIM_ROOT=/media/linux/mmsim61
export CDS_LIC_FILE=5280@ubuntu
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=$MMSIM_ROOT/tools/bin:$MMSIM_ROOT/tools/spectre/bin:$CDS_ROOT/tools/bin:$CDS_ROOT/tools/dfII/bin:$PATH
export MOZILLA_HOME=/usr/bin/netscape
hmm, actually it seems to be OK. Just two things are different from my .bashrc, so this might not related to it. Anyway, the differences are the following, at least worths a try:
1) add $CDS_ROOT/tools/spectre/bin to your path.
2) export MALLOC_CHECK=0
3) export LD_ASSUME_KERNEL="2.4.1"
the last one is for stability.
    holddreams
Before adding these issuses, I can start icfb& and draw the schematic,etc even if the two errors are still existing.
dump ubuntu, we use linux only because most ic eda tools run on linux, and RHEL officially support them and it is free to use. so dump fedora, dump ubuntu, down a rhel 3 or 4 or 5 copy and enjoy
It seems that you copied the wrong .cdsinit file to your home directory. You should use $CDS_ROOT/tools/dfII/cdsuser/.cdsinit as a template.
You may also comment out the loadi sentences near the end of .cdsinit.
Hughes is right.
I got the same problem when I install ic5141 usr6 on rhel4. I copied the file from tools/dfII/sample/local/cdsinit.
When I overlap the old .cdsinit by the file Hughes told, the error is gone.
Thanks.
