IC required for this purpose
Murugesh_89
Full Member level 5
Full Member level 5
India
I require an IC for the function given in the below image.
Some eight different analog signals given to the eight independent channels. The analog voltage in the each input channel can be read independently ( not simultaneously).
I put three select lines in the image for sample. Even the selection lines may be clock signal.
Please suggest me an IC if available.
thanks...
The circuit schematic shows a 8-way multiplexer. Check CMOS or 7400 series circuits, I think you can find such IC ready for your application.
If the switching frequency is in the kHz region you can use a CD4051 8-channel analog multiplexer. The active channel is determined by a 3-bit binary address.
