hamid159
Full Member level 3
Hi guyz,
I am trying to run i2c on Tiva C TM4C123GXL board. After Initiating the communication, Controller is always busy and does not come back in idle state. I don't know why buti am pretty sure, it is not sending the data to 24C04 because in "Master Bus Monitor" register i am seeing the SCL and SDA always low. I wasted my whole day to solve the problem but no avail.
Here is the code.
PS: i connected the pull up resistors to SCL and SDA.
Here is the code.
* main.c
#include "registers_addresses.h"
void Init(void);
void GPIO_PORTF_Init(void);
int main(void) {
int i;
* Initialization for LED
GPIO_PORTF_Init();
* Initialization for PORTB and I2C
Init();
while(1){
* Slave Adress 0b10100000
Write(((I2C0_BASE)|(I2CMSA)), (0xA0));
* Memory Address 0x5
Write(((I2C0_BASE)|(I2CMDR)), (0x00000005)); // this is address
* Start the communication and run (Start bit and run)
Write(((I2C0_BASE)|(I2CMCS)), (0x00000003)); // start and run
* Wait until the controller is not busy
while(((Read(((I2C0_BASE)|(I2CMCS))))&0x1)); // run until busy flag is 0
* Check for error
if(((Read(((I2C0_BASE)|(I2CMCS))))&0x2)){
Write(((GPIO_PORTF_BASE)|(DATA)|((1<<1)<<2)), (1<<1)); // if there is error, turn ON the LED
else{
Write(((GPIO_PORTF_BASE)|(DATA)|((1<<1)<<2)), ~(1<<1)); // turn OFF the LED
* Insert this data to 0x5 location
Write(((I2C0_BASE)|(I2CMDR)), (0x000000FF)); // this is data
* run again and put stop bit at the end
Write(((I2C0_BASE)|(I2CMCS)), (0x00000005)); // stop and run
* Check for errors
else {
* Toggle LED
for(i=0;i<200000; i++);
return 0;
void Init(void){
* Enable Clock for I2C 0 module
WritewithOR(((SYS_BASE)|(RCGCI2C)), (1<<0));
* Enable Clock for GPIO PORTB
WritewithOR(((SYS_BASE)|(RCGCGPIO)), (1<<1));
* Enable Alternate Functionality for PB2(SCL) and PB3(SDA)
WritewithOR(((GPIO_PORTB_BASE)|(AFSEL)), (1<<2)|(1<<3));
* Enable Open Drain for PB3 (SDA)
WritewithOR(((GPIO_PORTB_BASE)|(ODR)), (1<<3));
* Select Alternate Functionality I2C0 for PB2 and PB3
WritewithOR(((GPIO_PORTB_BASE)|(PCTL)), (0x00003300));
* I2C0 is master device
Write(((I2C0_BASE)|(I2CMCR)), (0x00000010));
* Time Period register value
Write(((I2C0_BASE)|(I2CMTPR)), (0x00000009));
void GPIO_PORTF_Init(void){
WritewithOR(((SYS_BASE)|(RCGCGPIO)), (1<<5));
WritewithOR(((GPIO_PORTF_BASE)|(DIR)), (1<<1));
WritewithOR(((GPIO_PORTF_BASE)|(DEN)), (1<<1));
