I2c communication with sht21
vinay shabad
Junior Member level 3
hiii i am writing program for communication betwwen i2C and SHT21 sensor i have found some example code with the help of that i wrote mine but it is having some errors
void I2c_init ()
//Ready
I2C> W //<<< Set 3.3v power supply on
Power supplies ON
I2C> (1) // <<< Search device on I2C bus//Searching I2C address space. Found devices at:
0x80(0x40 W) //<<< SHT21 is found
I2C> [0x80 0xE3][0x81 %:1000 r:3] // <<< start measure temperature and read value
I2C START BIT
WRITE: 0x80 ACK
WRITE: 0xE3 ACK
I2C STOP BIT
I2C START BIT
WRITE: 0x81 ACK
DELAY 1000ms
READ: 0x59 ACK 0x4C ACK 0x64
NACK
I2C STOP BIT
I2C> [0x80 0xE5][0x81 [%:1000] r:3] //<<< start measure humidity and read value
I2C START BIT
WRITE: 0x80 ACK
WRITE: 0xE5 ACK
I2C STOP BIT
I2C START BIT
WRITE: 0x81 ACK
DELAY 1000ms
READ: 0x8B ACK 0x22 ACK 0xDD
NACK
I2C STOP BIT
I2C>
errors :program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i.c:10: error: syntax error before 'I2C'
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i.c:14: error: stray '%:' in program
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i.c:21:7: error: invalid suffix "ms" on integer constant
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i.c:25: error: stray '%:' in program
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i.c:32:7: error: invalid suffix "ms" on integer constant
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i.c:36:5: warning: no newline at end of file
can any one please help me i am not C language expert it would be appriciable if some one help.Thankyou in advance
i am really sorry i found this example in net i too dn't understand in which language it is, but i am trying this programm in to C language but i am not expert in C language so can any one can change same programme to c language please.
Thankyou in advance
PIC24F16KA102 microcontroller
MPLAB ,C30 compiler
---------- Post added at 14:29 ---------- Previous post was at 14:27 ----------
the value in above programme are based on SHT21 datasheet which is excatly right i verified it
It's no programming language at all. Either a kind of debug output or the log output of an interactive tool operating the SHT21. Maybe it has been shown to give some hints what a C programm should do. You can hardly avoid to do some C coding on your own. Or find real C code for the device.
