DEVI403
Newbie level 5
Hellow everyone,
I am using spartan 3e and xilinx. The following is the code for i2c communiction using mpu 6050 as slave. I am trying to read who am i register. Resulting data through uart. Always I am getting FF only. Following is my code can anyone help me please???
//code
//code
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 -------------------------------------------------------------------------------- -- -- FileName: i2c_master.vhd -- Dependencies: none -- Design Software: Quartus II 32-bit Version 11.1 Build 173 SJ Full Version -- -- HDL CODE IS PROVIDED "AS IS." DIGI-KEY EXPRESSLY DISCLAIMS ANY -- WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT NOT -- LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A -- PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL DIGI-KEY -- BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR CONSEQUENTIAL -- DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR EQUIPMENT, COST OF -- PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS -- BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), -- ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER SIMILAR COSTS. -- -- Version History -- Version 1.0 11/1/2012 Scott Larson -- Initial Public Release -- Version 2.0 06/20/2014 Scott Larson -- Added ability to interface with different slaves in the same transaction -- Corrected ack_error bug where ack_error went 'Z' instead of '1' on error -- Corrected timing of when ack_error signal clears -- -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; ENTITY i2c_master IS PORT( clk : IN STD_LOGIC; --system clock reset_n : INOUT STD_LOGIC := '0'; --active low reset ena : IN STD_LOGIC; --latch in command addr : INout STD_LOGIC_VECTOR(6 DOWNTO 0); --address of target slave reg_addrr : IN STD_LOGIC_VECTOR(6 DOWNTO 0); rw : INout STD_LOGIC; --'0' is write, '1' is read data_wr : IN STD_LOGIC_VECTOR(7 DOWNTO 0); --data to write to slave busy : OUT STD_LOGIC; --indicates transaction in progress data_rd : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); --data read from slave ack_error : INOUT STD_LOGIC; --flag if improper acknowledge from slave sda : INOUT STD_LOGIC; --serial data output of i2c bus leds : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); scl : INOUT STD_LOGIC); --serial clock output of i2c bus END i2c_master; ARCHITECTURE logic OF i2c_master IS CONSTANT input_clk : INTEGER := 50_000_000; --input clock speed from user logic in Hz CONSTANT bus_clk : INTEGER := 400_000; --speed the i2c bus (scl) will run at in Hz CONSTANT divider : INTEGER := (input_clk/bus_clk)/4; --number of clocks in 1/4 cycle of scl TYPE machine IS(ready, start, command, slv_reg_adrs, wr, rd, slv_ack2,slv_ack3,mstr_ack, stop); --needed states SIGNAL state : machine := ready; --state machine SIGNAL data_clk : STD_LOGIC; --clock edges for sda SIGNAL data_clk_prev : STD_LOGIC; --data clock during previous system clock SIGNAL scl_clk : STD_LOGIC; --constantly running internal scl SIGNAL scl_ena : STD_LOGIC := '0'; --enables internal scl to output SIGNAL sda_int : STD_LOGIC := '1'; --internal sda SIGNAL sda_ena_n : STD_LOGIC; --enables internal sda to output SIGNAL addr_rw : STD_LOGIC_VECTOR(7 DOWNTO 0); --latched in address and read/write SIGNAL reg_addr_rw: STD_LOGIC_VECTOR(6 DOWNTO 0); SIGNAL data_tx : STD_LOGIC_VECTOR(7 DOWNTO 0); --latched in data to write to slave SIGNAL data_rx : STD_LOGIC_VECTOR(7 DOWNTO 0); --data received from slave SIGNAL bit_cnt : INTEGER RANGE 0 TO 7 := 7; --tracks bit number in transaction SIGNAL stretch : STD_LOGIC := '0'; --identifies if slave is stretching scl SIGNAL RD_FLAG : STD_LOGIC := '1'; SIGNAL EN_RD_FLAG : STD_LOGIC := '0'; BEGIN --generate the timing for the bus clock (scl_clk) and the data clock (data_clk) PROCESS(clk, reset_n) VARIABLE count : INTEGER RANGE 0 TO divider*4; --timing for clock generation BEGIN IF(reset_n = '0') THEN --reset asserted stretch <= '0'; count := 0; ELSIF(clk'EVENT AND clk = '1') THEN data_clk_prev <= data_clk; IF(count = divider*4-1) THEN --end of timing cycle count := 0; --reset timer ELSIF(stretch = '0') THEN --clock stretching from slave not detected count := count + 1; --continue clock generation timing END IF; CASE count IS WHEN 0 TO divider-1 => --first 1/4 cycle of clocking scl_clk <= '0'; data_clk <= '0'; WHEN divider TO divider*2-1 => --second 1/4 cycle of clocking scl_clk <= '0'; data_clk <= '1'; WHEN divider*2 TO divider*3-1 => --third 1/4 cycle of clocking scl_clk <= '1'; --release scl IF(scl = '0') THEN --detect if slave is stretching clock stretch <= '1'; ELSE stretch <= '0'; END IF; data_clk <= '1'; WHEN OTHERS => --last 1/4 cycle of clocking scl_clk <= '1'; data_clk <= '0'; END CASE; END IF; END PROCESS; --state machine and writing to sda during scl low (data_clk rising edge) PROCESS(clk, reset_n) BEGIN IF(reset_n = '0') THEN --reset asserted state <= ready; --return to initial state busy <= '0'; --indicate not available scl_ena <= '0'; --sets scl high impedance sda_int <= '1'; --sets sda high impedance bit_cnt <= 7; --restarts data bit counter data_rd <= "00000000"; --clear data read port reset_n <= '1'; ELSIF(clk'EVENT AND clk = '1') THEN IF(data_clk = '1' AND data_clk_prev = '0') THEN CASE state IS WHEN ready => --idle state IF(ena = '1') THEN --transaction requested addr <= "1101000"; rw <= '0'; busy <= '1'; --flag busy addr_rw <= addr & rw; --collect requested slave address and command data_tx <= data_wr; --collect requested data to write RD_FLAG <= '1'; EN_RD_FLAG <= '0'; state <= start; --go to start bit ELSE --remain idle busy <= '0'; --unflag busy state <= ready; --remain idle END IF; WHEN start => --start bit of transaction IF EN_RD_FLAG = '1' THEN RD_FLAG <= '0'; busy <= '1'; sda_int <= addr_rw(bit_cnt); --set first address bit to bus state <= command; ELSE busy <= '1'; --resume busy if continuous mode sda_int <= addr_rw(bit_cnt); --set first address bit to bus state <= command; --go to command END IF; WHEN command => --address and command byte of transaction IF(bit_cnt = 0) THEN --command transmit finished sda_int <= '1'; --release sda for slave acknowledge bit_cnt <= 7; --reset bit counter for "byte" states state <= slv_reg_adrs; --go to slave acknowledge (command) ELSE --next clock cycle of command state bit_cnt <= bit_cnt - 1; --keep track of transaction bits sda_int <= addr_rw(bit_cnt-1); --write address/command bit to bus state <= command; --continue with command END IF; WHEN slv_reg_adrs => --slave acknowledge bit (command) IF EN_RD_FLAG = '1' THEN EN_RD_FLAG <= '0'; sda_int <= '1'; --release sda from incoming data state <= rd; --go to read byte ELSIF(bit_cnt = 0) THEN --command transmit finished sda_int <= '1'; --release sda for slave acknowledge bit_cnt <= 7; --reset bit counter for "byte" states state <= slv_ack2; --go to slave acknowledge (command) ELSE --next clock cycle of command state bit_cnt <= bit_cnt - 1; --keep track of transaction bits sda_int <= reg_addr_rw(bit_cnt-1); --write address/command bit to bus state <= slv_reg_adrs; --continue with command END IF; WHEN slv_ack2 => IF RD_FLAG = '1' THEN --addr <="1101000"; --rw <= '1'; --addr_rw <= addr & rw; EN_RD_FLAG <= '1'; addr_rw <= "11010001"; state <= start; ELSIF(addr_rw(0) = '0') THEN --write command sda_int <= data_tx(bit_cnt); --write first bit of data state <= wr; --go to write byte ELSE --read command sda_int <= '1'; --release sda from incoming data state <= rd; --go to read byte END IF; WHEN wr => --write byte of transaction busy <= '1'; --resume busy if continuous mode IF(bit_cnt = 0) THEN --write byte transmit finished sda_int <= '1'; --release sda for slave acknowledge bit_cnt <= 7; --reset bit counter for "byte" states state <= slv_ack3; --go to slave acknowledge (write) ELSE --next clock cycle of write state bit_cnt <= bit_cnt - 1; --keep track of transaction bits sda_int <= data_tx(bit_cnt-1); --write next bit to bus state <= wr; --continue writing END IF; WHEN rd => --read byte of transaction busy <= '1'; --resume busy if continuous mode IF(bit_cnt = 0) THEN --read byte receive finished IF(ena = '1' AND addr_rw = addr & rw) THEN --continuing with another read at same address sda_int <= '0'; --acknowledge the byte has been received ELSE --stopping or continuing with a write sda_int <= '1'; --send a no-acknowledge (before stop or repeated start) END IF; bit_cnt <= 7; --reset bit counter for "byte" states leds <= data_rx; data_rd <= data_rx; --output received data state <= mstr_ack; --go to master acknowledge ELSE --next clock cycle of read state bit_cnt <= bit_cnt - 1; --keep track of transaction bits state <= rd; --continue reading END IF; WHEN slv_ack3 => --slave acknowledge bit (write) IF(ena = '1') THEN --continue transaction busy <= '0'; --continue is accepted addr_rw <= addr & rw; --collect requested slave address and command data_tx <= data_wr; --collect requested data to write IF(addr_rw = addr & rw) THEN --continue transaction with another write sda_int <= data_wr(bit_cnt); --write first bit of data state <= wr; --go to write byte ELSE --continue transaction with a read or new slave state <= start; --go to repeated start END IF; ELSE --complete transaction state <= stop; --go to stop bit END IF; WHEN mstr_ack => --master acknowledge bit after a read IF(ena = '1') THEN --continue transaction busy <= '0'; --continue is accepted and data received is available on bus addr_rw <= addr & rw; --collect requested slave address and command data_tx <= data_wr; --collect requested data to write IF(addr_rw = addr & rw) THEN --continue transaction with another read sda_int <= '1'; --release sda from incoming data state <= rd; --go to read byte ELSE --continue transaction with a write or new slave state <= start; --repeated start END IF; ELSE --complete transaction state <= stop; --go to stop bit END IF; WHEN stop => --stop bit of transaction busy <= '0'; --unflag busy state <= ready; --go to idle state END CASE; ELSIF(data_clk = '0' AND data_clk_prev = '1') THEN CASE state IS WHEN start => IF(scl_ena = '0') THEN --starting new transaction scl_ena <= '1'; --enable scl output ack_error <= '0'; --reset acknowledge error output END IF; WHEN rd => --receiving slave data data_rx(bit_cnt) <= sda; --receive current slave data bit WHEN slv_ack2 => --receiving slave acknowledge (write) IF(sda /= '0' OR ack_error = '1') THEN --no-acknowledge or previous no-acknowledge ack_error <= '1'; --set error output if no-acknowledge END IF; WHEN slv_ack3 => --receiving slave acknowledge (write) IF(sda /= '0' OR ack_error = '1') THEN --no-acknowledge or previous no-acknowledge ack_error <= '1'; --set error output if no-acknowledge END IF; WHEN stop => scl_ena <= '0'; --disable scl WHEN OTHERS => NULL; END CASE; END IF; END IF; END PROCESS; --set sda output WITH state SELECT sda_ena_n <= data_clk WHEN start, --generate start condition NOT data_clk WHEN stop, --generate stop condition sda_int WHEN OTHERS; --set to internal sda signal --set scl and sda outputs scl <= '0' WHEN (scl_ena = '1' AND scl_clk = '0') ELSE 'Z'; sda <= '0' WHEN sda_ena_n = '0' ELSE 'Z'; END logic;
