I wish to make a 555 circuit myself?
greentree
Member level 5
The center of world!
Hi every body*
At first i must say that i built the 555 circuit ... but it didn't work good!
RS flipflop worked but always R and S was high!?
I cann't understand what happened to it !
And i must say too that i built RS flipflop with two NAND gates . how can i make it with transistor.
You will have to show your circuit for anyone to help.
doesn't make sense. Check what you expect from the logic you have designed and see if it behaves correctly. I believe a simple RS flip-flop using NAND gates produces inverted outputs and the inputs are inverted as well, but I am not sure.
It is possible that the 555 circuit you are using shows an RS flip-flip with input & output logic different to yours and you will need some inverters to correct the logic.
Keith.
You should have a resistor in Q1 base.
Try connecting Q1 base through a resistor to OUT not U4.
Keith.
oops!
Yes you're right.
I forget it . thank you , i put it an say you its result...
Best wishes
Green tree
Don't forget to move the connection to OUT as well. If you follow the logic through it will get stuck with the output high with the logic you have (which is what is happening). You need it so when OUT goes high it starts the discharge.
Keith.
