tonyyy
Member level 1
- Joined
- Dec 26, 2012
- Messages
- 38
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,663
Hi guys.
I guess I am close the solution but I would like to have your confirmation.
I bougth a usb-rs232 cable:
RS232 PL2303HX 1m Z54
This cable has a supply of 5V when connected to a PC. I want to test a wifi module (ESP8266). I understood that I need to drop the voltage to 3.3 probalby using 2-resistor circuit from the 5 V provided by the cable but I am still not sure if If can connect directly the TX and RX of the cable to the ones on the module. ( need to use teraterm for testing purpose).
What abut the rs232 level provided by the PC? As far as I understood the diode zener is necessary when I want to connect the module to a PIC but what about PC?
https://rayshobby.net/?p=9734
Thanks a lot
Thanks a lot
