Mohammed_
Newbie level 6
- Joined
- Mar 30, 2013
- Messages
- 13
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,381
Hi
In my project will be there two switches. One for send AT to gsm to make sure the gsm is work and switch number two when it`s 1 will send AT commands to send a message to a specific number.
Now I`ll explain more.
see this link .. **broken link removed**
I`ll use this circuit, in P1.6 here will be switch if 1 it will send AT to gsm ounce after that I want the response show on LCD.
And in P1.7 another switch, if 1 send AT+CMGF=1 then show response on lcd , then send AT+CMGW="+*********", then send a written message example "Hi".
See this link .. HERE
Code is here .. **broken link removed**
// Program to Interface GSM Module with 8051 microcontroller (AT89C51) without using PC
#include<reg51.h>
#define port P1
#define dataport P2 // Data port for LCD
sbit rs = port^2;
sbit rw = port^3;
sbit en = port^4;
int count,i;
unsigned char check,str[15];
bit check_space;
void init_serial() // Initialize serial port
TMOD=0x20; // Mode2
TH1=0xfd; // 9600 baud
SCON=0x50; // Serial mode=1 ,8-Bit data,1 Stop bit ,1 Start bit, Receiving on
TR1=1; // Start timer
void delay(unsigned int msec) // Function for delay
int i,j;
for(i=0;i<msec;i++)
for(j=0; j<1275; j++);
void lcd_cmd(unsigned char item) // Function to send command on LCD
dataport = item;
rs= 0;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcd_data(unsigned char item) // Function to display character on LCD
dataport = item;
rs= 1;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcd_data_string(unsigned char *str) // Function to display string on LCD
int i=0;
while(str!='\0')
lcd_data(str);
i++;
delay(10);
return;
void lcd()
lcd_cmd(0x38); // For using 8-bit 2 row LCD
delay(5);
lcd_cmd(0x0F); // For display on cursor blinking
delay(5);
lcd_cmd(0x80); // Set the cursor on first position of LCD
delay(5);
void transmit_data(unsigned char str) // Function to transmit data through serial port
SBUF=str; //Store data in SBUF
while(TI==0); //Wait till data transmits
TI=0;
void receive_data() interrupt 4 // Function to recieve data serialy from RS232 into microcontroller
RI=0;
str[++count]=SBUF; //Read SBUF
unsigned char byte_check() // Function to check carraige return and new line character
switch(str[0])
case 0x0a:
{ // Return 0x00 for new line
return 0x00;
break ;
case 0x0d:
{ // Return 0x01 for carriage return
return 0x01;
break ;
default :return 0x02 ; // Return 0x02 for characters except new line and carriage return
void main()
lcd(); // Initialize LCD
init_serial(); // Initialize serial port
count=(-1);
delay(500);
lcd_data_string("Ready");
delay(10);
lcd_cmd(0x01);
IE=0x94;
transmit_data('A'); // Transmit 'A' to serial port
delay(1);
transmit_data('T'); // Transmit 'T' to serial port
delay(1);
transmit_data(0x0d); // Transmit carriage return to serial port
delay(50);
while(1)
if(count>=0)
check=byte_check(); // Check the character
if(check!=0x00)
if(check==0x01)
if(check_space==1) // Check previous character
lcd_data(0x20);
check_space=0;
else
lcd_data(str[0]);
check_space=1;
count--;
for(i=0;i<count;i++) // Shift the whole array to one left
str=str[i+1];
#include<reg51.h>
#define port P1
sbit rs = port^2;
sbit rw = port^3;
sbit en = port^4;
int count,i;
bit check_space;
TMOD=0x20; // Mode2
int i,j;
for(i=0;i<msec;i++)
dataport = item;
rs= 0;
rw=0;
en=1;
delay(1);
en=0;
return;
dataport = item;
rs= 1;
rw=0;
en=1;
delay(1);
en=0;
return;
int i=0;
while(str!='\0')
lcd_data(str);
i++;
delay(10);
return;
void lcd()
delay(5);
delay(5);
delay(5);
TI=0;
RI=0;
switch(str[0])
case 0x0a:
return 0x00;
break ;
case 0x0d:
return 0x01;
break ;
void main()
count=(-1);
delay(500);
delay(10);
lcd_cmd(0x01);
IE=0x94;
delay(1);
delay(1);
delay(50);
while(1)
if(count>=0)
if(check!=0x00)
if(check==0x01)
lcd_data(0x20);
check_space=0;
else
lcd_data(str[0]);
check_space=1;
count--;
str=str[i+1];
