I have no idea what you are talking about... Audio range is up to 20 kHz.leoren_tm said:i sot a problem on my transmitter.......
the range on my transmitter should be up the audio range..
but my fm receiver works only for below 20Khz...
but ill be on 30khz....
help me all
tnx in advance
What if you try to explain again what the actual problem is? What frequency your transmitter works on, and what kind of receiver you have? The thing is the more you write the more confusion you cause.leoren_tm said:i dont have a problem on my trnsmitter...
only on the reciever...
this is a low cost implimentation...
huh???
wat if i use AM???
