waldopulanco
Member level 1
I need help about DC-AC Inverter
2 years ago i have created a 150 watts DC-AC Inverter (12 VDC input and 220VAC Output) i was found the Schematic Diagram here **broken link removed**
then after i built, i test it and it was fine with the 80 watts bulb i try to bulb 100 watts but the light was dim!! then i try it to Flourecent with starter but the output voltage was drop to 50vac during the start, and i try it to colored tv 80 watts but after the click the power button the output voltage from in verter was drop to 50vac!!
then i try it to simulate using Tina Design Suite and there is a problem to when i load a bulb of 100watts the output voltage was drop to 150vac!! but when i try to 50 watts bulb it was fine!!
here is the simulated diagram using Tina Design Suite!!
help me to make it perfect!! because my inverter was never to use because of this problem!!
thanks!!!
thanks!!!
