Function _OSCtxSw is copied from the Source Code of UCOS II.
Does the red part in the following context make sense? If I removed it, what result will I get.
PAGE ; /*$PAGE*/
; PERFORM A CONTEXT SWITCH (From task level)
; void OSCtxSw(void)
; Note(s): 1) Upon entry,
; OSTCBCur points to the OS_TCB of the task to suspend
; OSTCBHighRdy points to the OS_TCB of the task to resume
; 2) The stack frame of the task to suspend looks as follows:
; SP -> OFFSET of task to suspend (Low memory)
; SEGMENT of task to suspend
; PSW of task to suspend (High memory)
; 3) The stack frame of the task to resume looks as follows:
; OSTCBHighRdy->OSTCBStkPtr --> DS (Low memory)
; ES
; DI
; SI
; BP
; SP
; BX
; DX
; CX
; AX
; OFFSET of task code address
; SEGMENT of task code address
; Flags to load in PSW (High memory)
_OSCtxSw PROC FAR
PUSHA ; Save current task's context
PUSH ES ;
PUSH DS ;
MOV AX, SEG _OSTCBCur ; Reload DS in case it was altered
MOV DS, AX ;
LES BX, DWORD PTR DS:_OSTCBCur ; OSTCBCur->OSTCBStkPtr = SS:SP
MOV ES:[BX+2], SS ;
MOV ES:[BX+0], SP ;
CALL FAR PTR _OSTaskSwHook ; Call user defined task switch hook
MOV AX, WORD PTR DS:_OSTCBHighRdy+2 ; OSTCBCur = OSTCBHighRdy
MOV DX, WORD PTR DS:_OSTCBHighRdy ;
MOV WORD PTR DS:_OSTCBCur+2, AX ;
MOV WORD PTR DS:_OSTCBCur, DX ;
MOV AL, BYTE PTR DS:_OSPrioHighRdy ; OSPrioCur = OSPrioHighRdy
MOV BYTE PTR DS:_OSPrioCur, AL ;
LES BX, DWORD PTR DS:_OSTCBHighRdy ; SS:SP = OSTCBHighRdy->OSTCBStkPtr
MOV SS, ES:[BX+2] ;
MOV SP, ES:[BX] ;
POP DS ; Load new task's context
POP ES ;
POPA ;
IRET ; Return to new task
_OSCtxSw ENDP
