Jul 16, 2007 #1 O OMEsystem Advanced Member level 4 Joined Dec 1, 2005 Messages 102 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 2,061 Who has the s3p file of 50 to 100 ohms smd type balun which operates at 2.4GHz? any datasheet or application are welcome to upload. Thanks,
Jul 16, 2007 #2 N nxing Advanced Member level 1 Joined May 10, 2004 Messages 421 Helped 25 Reputation 50 Reaction score 10 Trophy points 1,298 Location China Activity points 2,856 check out Murata's website, probably you can find some or coilcraft's website. Good Luck
Jul 16, 2007 #3 Mazz Advanced Member level 2 Joined Nov 3, 2001 Messages 674 Helped 131 Reputation 262 Reaction score 50 Trophy points 1,308 Activity points 5,463 Spar file: https://www.johansontechnology.com/library/awr/Baluns/2450BL14B100.s3p Data sheet https://www.johansontechnology.com/products/rfc/blct/JTI_Balun-2450BL14B100_12-03.pdf A lot of other balun at https://www.johansontechnology.com/products/rfc/blct/ I hope it can help. Mazz
Jul 17, 2007 #4 O OMEsystem Advanced Member level 4 Joined Dec 1, 2005 Messages 102 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 2,061 Mazz said: Spar file: https://www.johansontechnology.com/library/awr/Baluns/2450BL14B100.s3p Data sheet https://www.johansontechnology.com/products/rfc/blct/JTI_Balun-2450BL14B100_12-03.pdf A lot of other balun at https://www.johansontechnology.com/products/rfc/blct/ I hope it can help. Mazz Click to expand... I saw there is filter balun combination, is it a popular solution?
Jul 17, 2007 #5 Mazz Advanced Member level 2 Joined Nov 3, 2001 Messages 674 Helped 131 Reputation 262 Reaction score 50 Trophy points 1,308 Activity points 5,463 Yes, as both functions are needed from your system, you'll save area and cost with only one part. Mazz
