I need phase shift PWM application
alphi
Advanced Member level 1
anyone can send me the reference of phase shift pwm application
Go to ti.com and enter phase shift into search box. Good Luck.
TI have not detail application design,anyone can send me other resource.
thank you
What kind of design u are planning? If u use a uC, u can make this quite simple in using an internal ressource (e.g. 8051 or the bigger PICs). U must only adjust some register and it works. Mostly all motor-application work this way.
Or do u search for a single chip-solution? Then u can use some of the 555-application.
Maybe I don't understand your question... :???:
