the rs485 interface is elementary, you put an 75176 or max485 in your circuit and interface is made.
Simply connect pin 8 at +V pin 4 at negative
pin 1 at your micro serial input and pin 4 at your micro serial output.
Pin 2 and 3 are connect together, tired to negativa in rx mode or to +5V in tx mode
