I need help in my circuit to generate dead time
dor8
Junior Member level 1
I have a problem with my circle that the drivers are burned (pin 4 shorter to pin 2) or the drivers are not working properly (HO takes out constant signal regardless of to his entry).
I use in UCC27200 driver.
Can some of the problems were caused because I don’t have delay time between switching of the transistors ,So I want to create a circle of delay (Figure 2).
My goal is to create a time delay of a 100n but I need help in calculating the components that would give me the time delay.
And generally how I calculated delay tie in RC Circle?
RC circuit behaviour follows a simple exponential function. With a threshold voltage of 0.5*Vdd, the delay is 0.7*RC. See https://en.wikipedia.org/wiki/Rc_circuit
Consider a 74HC gate output resistance in a 50 to 100 ohm range, the resistors in your delay circuit should be at least factor 10 larger.
The 1nF cap may be drawing excess current from drivers in UCC27700, have RdsOn in the range of 2 to 4 Ohms. You may calc. driver temp. rise from this. Normally gate capacitance can rise this high during transition swing, depending MOSFET specs. Change 30R to 100R or 200R.
Measure all component temp rise. and all gate signals with very short probe tip & ring . <1cm
From what I understand the capacitor can make me a problem?
I just must make a delay- of switching and that the only way I know .
Taking SunnySkyGuy's recommendation, and changing the resistance to 200 ohms.
Here is a simulation, showing that by changing the capacitor to 500 pF, you get the desired delay of 100 nSec.
The op amp is not necessary, but it performs as your following device might. Its output changes state when the capacitor transitions above or below 3V.
Brad's simulation demonstrates well the asymmetry of delay.
My intent was to use the Ciss of the MOSFET instead which increases rapidly as the Vgs rises above threshold. But this nonlinear capacitance is shown below for an N type from ON Semi.
