moh.moawed
Newbie level 3
- Joined
- Oct 21, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 18
i need a Matlab code for feature extraction with Discrete Fourier, Wavelet, Cosine, and Sine transform
What kind of features you want to extract. ...image/speech ...Codes are easily avail on Matlab site
Ex. https://www.mathworks.com/matlabcen...g-multisignal-wavelet-transform-decomposition
For fourier and wavelet :- https://www.codeproject.com/Articles/479975/Image-Tracking-and-Computer-Vision-Using-Fourier-I
These are sample codes only...not sure whether it will give the efficient result in your case ...But you can read algo from this page an implement
% This is a program for extracting objects from an image. Written for vehicle number plate segmentation and extraction
% Authors : Jeny Rajan, Chandrashekar P S
% U can use attached test image for testing
% input - give the image file name as input. eg :- car3.jpg
clc;
clear all;
k=input('Enter the file name','s'); % input image; color image
im=imread(k);
im1=rgb2gray(im);
im1=medfilt2(im1,[3 3]); %Median filtering the image to remove noise%
BW = edge(im1,'sobel'); %finding edges
[imx,imy]=size(BW);
msk=[0 0 0 0 0;
0 1 1 1 0;
0 1 1 1 0;
0 1 1 1 0;
0 0 0 0 0;];
B=conv2(double(BW),double(msk)); %Smoothing image to reduce the number of connected components
L = bwlabel(B,8);% Calculating connected components
mx=max(max(L))
% There will be mx connected components.Here U can give a value between 1 and mx for L or in a loop you can extract all connected components
% If you are using the attached car image, by giving 17,18,19,22,27,28 to L you can extract the number plate completely.
[r,c] = find(L==17);
rc = [r c];
[sx sy]=size(rc);
n1=zeros(imx,imy);
for i=1:sx
x1=rc(i,1);
y1=rc(i,2);
n1(x1,y1)=255;
end % Storing the extracted image in an array
figure,imshow(im);
figure,imshow(im1);
