I would like to build a unit that works as follows.
Two devices are plugged into the unit (devices and unit run off 110V AC).
When device A is turned on, the unit will detect the current flow and automatically turn on device B. Like wise, when device A is turned off, the unit will turn device B off as well.
Please note that both devices are high current devices (approx 10 to 12 amps). I would like to do this via a solid state design if I can avoid using relays.
I appreciate the help.
