garg29
Advanced Member level 1
Refrence voltage of ADC
I'm using PIC16F688 controller to measure a analog voltage. The problem is my supply voltage is 5.04 volts instead of 5.00 volts ( the power supply is simply based on 7805) which varies the refrence voltage of ADC.This creates a error like if ADC output should be 730 it will give 735 with 5.04 volts reference, & from piece to piece of 7805 this supply voltage varies from 5.01 to 5.06. How can I handle this problem ? All other pins of the uC are reserved.
Thanks in advance,
Regards,
Garg
Thanks in advance,
Regards,
Garg
