kompatibel
Newbie level 3
hello ,i come here for help
1 .I am using IR2110 for driving mosfets of full bridge inverter. I have noticed that even though i am givn 15V as Vcc to driver, the gate pulses are 13.8 V to lower switch. why is this happening
Is there any voltage regulator available in the market that can regulate the DC voltage up to 60V and can charge the 48V Lead acid batteries?
2.My question is rather simple, but I preferred being misinformed inform me before use to avoid any health problems.
Should have used goggles to use this laser pointer?
I do not intend to look directly at the exit point of the pointer, but being given that it is a 300mw green laser in puissantlaser.com/c-2/p-1041.html the light spot is really powerful, 2min dazzled look, a bit like a camera flash pictures.
I understand that very bright light could damage the vision and therefore faillais wear goggles staring point
I have used LM338K to make my 24V lead acid battery Charger with auto cut off circuitry sucessfully. now i want to make 48V and 36V battery chargers, i also want the charging current up to 30A. Please help me about that. i need guidance from Experts
