cmi spectre
VSMVDD said:
oooooohohohohohohohohho
yawn
Hi~
Thanks for your tutorials.
Added after 1 hours 8 minutes:
truebs said:
I am not sure about the first point, i guess some problem with the environment settings.
for second point , make sure the model names that u used is same (in input netlist and .scs/.mod file).
Only existence of .scs file will not make it all fine, u must check inside the .scs file for various model names and parameters are rightly specified.
3) As far as i know, these are just 3 formats of specifying the models. These differ slightly in the format. However .scs is the format accepted and works best with Cadence simulator.
I hope it helps.
bye
Thanks for your replying. I have attached the error message I got from cadence machine. I thought it might caused by the library path definition. How do you think about the following error message? Thanks again.
Command line:
spectre -env artist5.0.0 +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre1_10385_2 -format psfbin -raw ../psf \
input.scs
spectre pid = 10488
Loading /space/cadence/ic5.0/tools.sun4v/spectre/lib/cmi/3.0/libinfineon_sh.so
Loading /space/cadence/ic5.0/tools.sun4v/spectre/lib/cmi/3.0/libnortel_sh.so
Loading /space/cadence/ic5.0/tools.sun4v/spectre/lib/cmi/3.0/libphilips_sh.so
Loading /space/cadence/ic5.0/tools.sun4v/spectre/lib/cmi/3.0/libstmodels_sh.so
spectre (ver. 5.00.32.051603 -- 16 May 2003).
Notice from spectre.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `input.scs' on if2a55f6 at 12:46:50 PM, Fri Nov 24, 2006.
Error found by spectre during circuit read-in.
"input.scs" 9: Unable to open input file
`/space/EUROPRACTICELib/ams_V3.50/spectre/b35/cmos53.scs'.
No such file or directory.
spectre terminated prematurely due to fatal error.
