I dont wont to save the "space" in SRAM, Help me ?
Bebo
UAE
Hi every body ...
i wrote a code that receive data RS232 and save it on the SRAM ... and its work :)
But i have problem...
i don't wont to save a " space " ,which equal 20 in hex, with the data ...i tried to modify my code but i failed
PLZ... help me :(
this my code :
#### MEM_SRAM #####################################
module MEM_SRAM (
Data_Bus, // Data Bus
Address, // RAM Address
nRD, // RAM Read Enable
nWR, // RAM Write Enable
nCE, // RAM Chip Enable
nUB, // RAM Upper Byte
nLB, // RAM Lower Byte
Data_In,
Address_In,
RxD_endofpacket,
LEDR,
clk); // Write Enable
output reg [17:0] Address; // RAM Signals // include
inout [7:0] Data_Bus;
output nRD, nWR;
output nUB, nLB;
output nCE;
reg [1:0] WE; // Write Enable
input [17:0] Address_In ;
input [7:0] Data_In;
input RxD_endofpacket;
output [17:0] LEDR; // include reg
input clk;
assign nUB = 1'b1; // Disable Upper Byte
assign nLB = 1'b0; // Enable Lower Byte
assign nCE = 1'b0; // Enable Chip
assign nRD = 1'b0; // Read Enable
assign nWR = !WE; // Write Enable
assign Data_Bus = WE? Data_In : 8'hzz;
always @(posedge RxD_endofpacket)
if(RxD_endofpacket==1)
begin
if ( Data_In == "00100000")
WE=1'b0;
else
WE=1'b1;
Address <= Address + 1;
end
assign LEDR = Address;
This is the module that combines the receiver module and the SRAM module
module serialfun(clk, RxD, RxD_data, nWR,nCE,
nRD,Address, Data_Bus,LED,Data_In,nUB,nLB,RxD_endofpacket,RxD_data_ready,RxD_idle);
input clk;
input RxD;
output RxD_idle;
output RxD_endofpacket;
output RxD_data_ready;
output nRD;
output nWR, nCE;
reg [1:0] WE;
output [17:0] Address;
output [17:0] LED;
output nUB,nLB;
//wire RxD_data_ready;
output [7:0] RxD_data;
async_receiver deserializer(.clk(clk), .RxD(RxD), .RxD_data(RxD_data), .RxD_endofpacket(RxD_endofpacket),.RxD_idle(RxD_idle),.RxD_data_ready(RxD_data_ready) );
reg [17:0] Address_In ;
MEM_SRAM u0(.Data_Bus(Data_Bus), .Address(Address), .nRD(nRD), .nUB(nUB), .nLB(nLB),
.nWR(nWR), .nCE(nCE), .Address_In(Address_In), .Data_In(RxD_data),.LEDR(LED),.RxD_endofpacket(RxD_endofpacket));
endmodule
Re: I dont wont to save the "space" in SRAM, Help
In your code, Address is always incremented when RxD_endofpacket==1.
It should look something like this:
  if ( Data_In == 'h20 )
     WE <= 1'b0;
  else begin
     WE <= 1'b1;
  end
You might want to check your code.
1) The check for RxD_endofpacket==1 is redundant because of posedge RxD_endofpacket (should that be posedge clk instead?)
2) It looks like WE stays high until Data_In == 'h20
thank you devnull
i changed my code ..
the WE (Write Enable ) will enter the MEM code as input and i will check the if the data is " space " or any other data from out side and then sign WE to write or not to the memory.
and in the MEM code i will just increment the Address.
Do you think that my logic is writ or not ???
module that combines the receiver module and the SRAM module:
nRD,Address, Data_Bus,LED,Data_In,nUB,nLB,RxD_endofpacket,RxD_data_ready,RxD_idle,WE);
input clk;
input RxD;
output RxD_idle;
output nRD;
output nWR, nCE;
output reg WE;
output [17:0] LED;
output nUB,nLB;
begin
if ( RxD_data == 8'b00100000)
WE=1'b0;
else
WE=1'b1;
end
assign Data_Bus = WE? RxD_data : 8'hzz;
.nWR(nWR), .nCE(nCE), .Address_In(Address_In), .Data_In(RxD_data),.LEDR(LED),.RxD_endofpacket(RxD_endofpacket),.WE(WE));
endmodule [/color]
SRAM CODE :
module MEM_SRAM (
Data_In,
Address_In,
RxD_endofpacket,
LEDR,
WE,
output nRD, nWR;
output nUB, nLB;
output nCE;
input WE; // Write Enable
input clk;
begin
if(WE==1)
else
Address <= Address + 0;
end
###########################################3
The best way to determine if your code will work or not is to simulate and look at the waveforms.
i dont know what is wrong with my code ?? :/
when i send the data like ( for example) >>>1 then 2 then "space" then 3 then 4
the data saved like this in SRAM >>>> 1 then 2 then "space" then 4
i dont know why it save the "space" and skip 3 >>????
this is my whole project :
input clk;
input RxD;
output RxD_idle;
output nRD;
output nWR, nCE;
output reg WE;
output [17:0] LED;
output nUB,nLB;
begin
WE=1'b0;
else
WE=1'b1;
end
//assign Data_Bus = WE? RxD_data : 8'hzz;
endmodule
module MEM_SRAM (
Data_In,
Address_In,
RxD_endofpacket,
LEDR,
WE,
output nRD, nWR;
output nUB, nLB;
output nCE;
input clk;
begin
if(WE==1)
//else
//Address <= Address + 0;
end
endmodule
