You get some kind of demodulated signal, but not the intended base band signal, not even for AM. With "zero IF" or homodynef i set local oscilator frequency equal with carrier frequency then i have demodulate signal.
karesz said:If you dont have L+R & L-R ("coded") modulation= you must have a two transmitter receiver system...
Pls realyse; FM-Stereo TRX technique is relative old_ca. 50 years, to the time of 60tees are the public coding & receiving techniques others possible to build as nowadays.
K.
karesz said:Thes IC is developed for "communications Rx", they arent HIFI RX systems!!
They are good and selective systems, but with at i.e. 5-8 KHz bandwidth, these is cca half of your needs...
K.
