I can read and write a file in verilog, the image which i am reading is .bmp file, the values of the image is in 8bit(if we open in text editor the values appear in 8bit), now my problem is which are the values in the image are RGB values how to indentify RGB values in a image
there are plenty of open source bmp reader library online. I would suggest using one of them to remove the bmp header information and dumping just the image data then using $readmemh to read it into verilog.
