Hysterisis measurement
analogckt
Hello
I have a comparator with differential inputs and differential outputs. How can I measure the hysterisis of this comparator in Spice?
Please help
Thanks
ckt
I prefer to use controlled sources to take differential
voltages and make single ended, ground referred ones
that are nice and neat for whatever calculator, waveform
viewer or scripting language you may have. Plain SPICE
may not have such nice postprocessing, but if you can
make use of a cross() function, then things get real easy.
Find point of output crossing zero differential, read input
difference at that point, badda-bing.
But the details come down to dialect / software version.
If you don't have a decent results browser / viewer /
calculator, you might look at dumping raw data vectors
and parsing them for output cross, input value outside
the simulator.
Hello
Please help
Thanks
ckt
example ( assume IN= input Y =ouput)
Vinput IN 0 PWL ( 0 0 0.5s VSUPPLY 1s 0)
then measure statement to find hysteresis
.measure tran v_padh find V(IN) when V(Y)='VSUPPLY/2' TD=0s
.measure tran v_padl fin V(IN) when V(Y)='VSUPPLY/2' TD=0.5s
.measure tran HYSTERIS PARAM='v_padh-v_padl'
