Did you find the answer for your question, even i want to do the same thing what you posted.Even i am trying to find the hysteresis curve for a soft ferrite core using jile atherton model.any help that you could tell me would be great..
I want to find a way to determine dynamic bh curve in matlab or PSPICE because i have to check for which parameters of the jiles model the bh curve is same as experiment
The file i attached is from a paper which will show the block diagram in simulink but did not end up in a bh curve.
Thanks
